Douglas Thigpen
Just a heads up. Suppose to fix a lot of plug-in problems, hopefully it does. (Color Finesse PI, proDAD Mercalli, etc)
Also adds REDCODE support.
On first glance, the AVCHD support is *amazing*. Full-screen, full-quality, 720/24p and 720/60p. No "preview" mode, no dropped frames. And that's being edited on a LAPTOP.
AVC-I is planned so I hear and I can't wait to see what's next.
It looks like AVC-Intra is included with the new 4.1 update. If you create a new sequence and click on the general tab, you will see the new Red Cinema and AVC-Intra editing modes in the drop down.
Well, those presets are there, but there is not AVC-Intra support from PPro CS4 yet...I tried importing some footage and it doesn't come in.
Well, the frame export option is still screwed up. I don't know why they make you open up an entirely different menu to export a frame.
Also I'm still running into the bug where AME will export the entire sequence instead of just the work area. How'd they screw that up?
Great stuff and keep up the good work! Oh, and please give us the ability to export our Premiere projects to either AUDITION or Soundbooth as a MULTITRACK project! That's all that's missing. As for now, I'll just use Vegas for my sound via AAF.
I believe it was more complicated before the 4.1 update - not as smooth or easy as CS3 or previous versions, but easier now.
I believe that's a known issue - check the readme file for the 4.1 update.
You can do a multitrack edit in soundbooth allready using the .asnd format.
And I'm really hoping that the next installment of Audition wil support the format!!!
- Derrick
How do you save your Premiere project as an .asnd file? I just tried but can't find anything for that.
When I mentioned that, I was talking about a way to get your Premiere project's audio files set up in a multitrack project like they are in the Premiere timeline.
As far as I know, you can't but if I'm wrong, please let me know.
Thanks!
You actually use Dynamic Link to open up the Premiere Pro sequence in Soundbooth. Create a new multitrack file in Soundbooth then click on File/Adobe Dynamic Link/Import Premiere Pro Sequence. Select your sequence in the finder or explorer window and your sequence will be brought in to work on.
Right, but as far as I know, that doesn't open it up as a multitrack project. It brings in all the audio as one track. Kinda useless for real sound work.![]()
