Where are the sony LUTs? I'm sure I had them once but can't find them now.
Up until now, I've just been using an S curve adjustment in something like MB Looks. I guess the Sony LUTs are going to be more accurate to get to a 709 style image?
Noah, I did have a look at the Impulz LUTs. Which ones do you prefer for the non-filmic 709 type look?
Easy as pie. There's even rec 709 presets in speedgrade you can tweak to get you closer to what you need.All you do in SG/Resolve is to take a correctly exposed shot, make curves/saturation/whatnot adjustments and export it. That way you can use your personal grade as a preset, aka LUT. Another option would be to use any effect from Premieres effects panel, make your adjustments and save the effect as a preset.
I've just tried the Impulz LUTs you mentioned. Agree - they look great
What's your normal workflow using them? Do you use them in Premiere / AE or Speedgrade / Resolve?
Wondering if the best route is to use them as a base and tweak / grade on top?
