Premiere CS4 4.1 is OUT!!!!!!!!!
From here: http://www.adobe.com/support/documentation/en/premierepro/4_1/Adobe_Premiere_Pro_CS4_1_0_ReadMe.pdf
New in this release
  • Additional support for REDCODE (please visit RED support for additional details).
  • Performance improvements to project load time.
  • Improvements to AVCHD support.
  • Performance enhancements for DV/HDV playback.
  • Support for Avid captured DV or IMX footage. (Please see www.adobe.com/go/kb409079 for additional information).
  • Export media to a still format now bypasses the AME render queue.
  • Enabled .VOB extension support.
  • Third-party support
Notable fixes
  • All clips in last active sequence are no longer redbar when reopening project (#2278647)
  • Boris FX can get the clip dimensions for their filter setup dialog (#2274629)
  • CTRL+M is now the default shortcut for File‐>Export‐>Media (#2277908)
  • A bug that caused green frames in clips with 100% reverse speed applied has been fixed. (#2263918)
  • The last few frames of a time remapped clip are no longer rendered green (#2278907)
  • Adobe Premiere Pro can now open projects created in Adobe Premiere Elements 7. (#2267281)
  • ’Scale to Framesize’ on a clip in a sequence of matching frame size and PAR no longer causes the timeline to require rendering. (#2278908)
  • A bug that caused corruption in exported TIFF files has been fixed. (#252497)
  • Several issues with Adobe After Effects Filters and Track Mattes have been fixed. (#1882807,
  • #1876369)
  • Performance improvements have been made to Direct Manipulation (#2260316)
  • AVCHD 720p 30p are now imported correctly. (#2269541)
  • Relinking XDCAM EX clips that have been moved to a new directory is now more intuitive.
  • (#2272122)
  • A bug that caused fields to be reversed when rendering speed change on upper field first footage has been fixed. (#2260314)
  • A user can now copy and paste R3D footage from Adobe After Effects to Adobe Premiere Pro. (#1931580)
  • Several issues with effects that use track inputs, when the input track is a still have been fixed. (#2263816)
  • Playback performance of ProRes clips has been improved. (#2261047)
  • Playback performance of h.264 clips has been improved. (#1824690)
  • XDCAM EX clips no longer play one only audio track in the Source panel (#1929452)
  • A playback issue with Panasonic AG‐HMC150 recorded progressive AVCHD clips no longer causes application freeze (#2268148)
  • Blackmagic can now display titler output on external monitor (#2286733)
  • If a mapped drive is defined as the user folder for a roaming profile, Adobe Premiere Pro no longer crashes when attempting to write to the drive (#2291950)
Known issues
  • Progressive 720 Sony AVCHD media files show an interlaced frame rate in Media Browser and Metadata panel.
  • AVCHD 1080p 30 and 25 progressive clips are interpreted as interlaced files in Adobe Premiere Pro CS4 projects.
  • If the work area end position is greater than the last frame of the last clip in sequence, then entire sequence is exported instead of work area.
  • Setting sequence-marks stops playback if the multi-camera monitor is open.
  • When importing QuickTime clips in AME’s batch queue for export, certain types of metadata (such as timecode) will not be propagated to newly generated clips.
HOLY SH*****!!!!!!!
This thing actually works.
Tested 720/25p videos and it's playing back real time on my E6400 computer (Win 7 x64)!!!!!
1080/25p clips work as well!!!!! holy crap!!!!! (you need to set field order to progressive in interpret footage)
Weird, I was just about to jump in and ask who's using Premiere... I'm downloading updates right now...
It's definitely a lot faster now (application in general...loading, saving, closing) and the new AVCHD support is finally what one might have expected 7 or 8 months ago when CS4 was released.
Premiere also seems to handle memory much more efficiently now, using only what it needs at a given point and letting go of it when not using it.
Nice.
Ok...
so previously with my CS4 4.0 I had the AVCHD 1080 presets..
now after updating to CS4 4.1 I have lost my AVCHD preset and is now only left with DVCPROHD, DVCPRO50 and the rest of the SD and Mobile presets.
I try updating again, and it just says no more new updates.
What's going on?!?!
I want my AVCHD presets back!!! and i need the 720 60 preset.
Perfect timing! I have been wanting to edit 720p footage without transcoding to DVCproHD for a while now.
tested on a 2 core turion... wow 720 24p edits fine.. 720 60p chokes... Still better to convert to sd and edit than to edit native HD... or ill buy cineform
Ok...
What's going on?!?!
same here.....im registered/authorized also!!!
