Thomas Smet
Increase the contrast or make other big changes, do you start to see stripes in the waveform? If so your footage might be handled like 8 bit.
Sometimes it isn't as easy as that in a 32bit float environment. 32bit float will take a good looking shot in 8bits and typically keep it good looking by creating samples in between as needed. This can work in color sampling since we need subtle pixels differences. Fine detail doesn't need higher color depth. That is the opposite of image scaling where gradients can scale well and high detail looks horrible.
So cranking a grade in a 32bit float will likely not show much difference in 8bit or 10bit as long as the 8bit had enough samples for the color.
Only way to really tell if CS6 works with 10bit properly is to shoot a 8bit sample and 10bit sample of a subtle color gradient like a blue sky with the GH5 and see if there is a banding difference between the two. You have to shoot something that would typically fall apart in 8bit. Not always easy to do. This is why 10bit has been kind of a heavily debated subject for a long time. You have to be in just the right condition to make 8bit fall apart. 8bit does not always equal bad. It just doesn't have the overhead to handle difficult situations.
