Yes. Works fine for RED and for Canon DSLR footage (though I would always transcode a Long-GOP codec to I-frame before editing on ANY NLE, regardless of "native support.") In fact, RED had a video at a post house where they did a long take with two REDs (split screen) shot a video with one, and, in real time, walked it over to an edit suite, copied footage off the card, and dropped it straight into FCP...no converting, no importing.Can FCP import any DSLR or RED footage NATIVELY
and play footage of different frame rates together instantly?
I have used a Mac since the beginning of time, so I decided to start with FCE based on ads claiming that it does ALMOST everything as FCP, but that "almost" leaves out a lot–including a 24fps timeline.
I have to upgrade but want to know major differences between FCP and Adobe's counter part before I put down that kind of money (I'm tired of wasting it). Maybe I should put my past experience with Adobe behind me, but that last incident left a bad taste in my mouth, which is why I didn't jump right into Adobe in the first place.
Thanks again for the help!
Ummm...yes. Just set your sequence setting to whatever the highest framerate of footage is and all other footage should play fine within that timeline. For example if you want to mix 60p and 24p footage (and have each maintain it's normal motion qualities) put them both in a 60p timeline. From my experience it doesn't seem to need any rendering. I've never done a project like this but I've worked with people that have and know it's perfectly doable.
my worthless 0.2 cents:
i started learning on FCP Studio 2 on a mac mini, then a an imac 3Ghz....but at the time all i was doing was SD. it was fast enough, then i got my HMC40, my god...it would take a really long time to finish work...so, there i was...stuck in a OS, with a crappy computer, with no money.
finally saved enough, purchased adobe CS4 and a moderately fast computer and been happy ever since...all the money i've spent on my setup would probably not even cover the taxes if i had gone Mac Pro.
sorry, guys..i use macs at work and i think they are a great piece of machinery, but leave them for people with money...
i'd rather buy a ford fiesta and have money left over for gas than a mclaren F1 and ask people to fill up for me![]()
Have you tried to export AE project into PP project? Just open up the exported project from PP. Also AE can import PP CS5 project. CS5 thumbs up!
