I tried to find the answer from other threads but no one seems to have the solution. So the problem is how to power my shuttle because the internal battery will last only one hour. I'm transferring to V-lock batteries so I need a cable from D-tap to whatever the 12V plug in the shuttle is. Can anyone confirm this and point me to the right direction? I'll get the Zacuto Zwiss plate (http://store.zacuto.com/Zwiss-Plate.html) and will bolt a v-lock mount on the other side and the hyperdeck on other. This leads to my next question: do I have to make a custom back plate for the shuttle to be able to mount it or is there a solution that I can just buy? Too bad that there's no thread holes on the back plate
I'm also open for better options for mounting the v-lock battery and the shuttle. One more question, where can I find D-tap to 4-pin right angle xlr cable or is the right angle cable going to interfere with the F3 body? Many questions but I desperately want to get this solution working
