gkantziper
Esteemed Member
The AJ-PCD2 requires power and data from 2 separate USB ports. What if you only have 2 USB ports and need to transfer to a USB drive? Can you power the AJ-PCD2 with some other device like an iPhone charger?
(Please don't answer unless you have actually done this many times without damage to the AJ-PCD2.)
The AJ-PCD2 says 5V .5A on the back and the iPhone charger says 5V 1A. Too much power?
Thanks.
Thanks.
