Brian Petersen
I have a pretty powerful 15" Powerbook:
1.67 Ghz
2 GB Ram
ATI Mobility Radeon 9700 Graphics card with 128 MB of VRAM
I've started to edit DVCproHD stuff from my HVX and I've had some hang ups. I can edit 24p stuff without much of a skip or dropped frame, but whenever I deal with 720p60 (not slow mo. 60p playback) my system can't handle it and I'll get a dropped frame after a minute of playback or so.
I understand that the 60p stuff is more intensive. The 60p stuff has a data rate in FCP of 14.1, while the 24p stuff has a data rate of 5.9. Am I to understand that my powerbook with all the fixings can only edit 24p stuff with the lower data rate? If so, then that's pretty sad. Hopefully I'm just not doing something right. Are any of you editing 60p stuff on a powerbook with no problems?
Also, someone explain to me the data rate that FCP is giving me for my files. I understand the difference in data rate between the 60p stuff and the 24p stuff, but I don't get the actual numbers. I thought 720p60 was 100mbs. I guess that is different than the data rate FCP says the clip is at 14.1 MB/sec. Can someone explain to me the difference?
1.67 Ghz
2 GB Ram
