Power supply help
Brendalf
Hey gang. I'm having trouble getting the AC power supply for my 170 to work. When I first got my camera I just figured I got a defective one and never bothered to get it replaced. Just the other day though I happened to plug it in and to my surprise it worked!
After playing around with it for a couple minutes I've discovered that the slightest movement (even so much as a gentle tap) will cause it to pop off and shut down the camera. Does anyone else have this problem or better yet know a workaround?
yes, I have the EXACT problem but have not looked into it yet. Very cheap looking part. Seems like it could be more beefy and have a better fit.
Brian
Here are the replacement parts for the cable and the adapter if you want to purchase new.
http://www.spec-comm.com/store/index.php?l=product_detail&p=2310
http://www.spec-comm.com/store/index.php?l=product_detail&p=3869
Keep in mind if an accessory is bad when you open the box, you only have 10 days for it to be replaced under warranty.
Sincerely,
Andrew Hoffman
Vice President
Specialized Communications Corp.
20940 Twin Springs Dr.
Smithsburg, MD 21783-1510 USA
800-359-1858
301-790-0103
Fax: 301-790-0173
andrewh@spec-comm.com
Skype ID: Spec-Comm
www.spec-comm.com
www.twitter.com/speccomm
