Power and Time Lapse
jonnyh1968
Hello. Does anyone know what happens if the HVX loses power during a time lapse shoot? do you lose the file? Thanks, I'd woud test it and check myself but it is currently shooting the time lapse as I write this email.
thanks.
It saves to the P2 card so you'll lose like the last frame but your file won't be corrupt.
I do it all the time out in the field. I'll put in a fresh battery, set the time-lapse and then let it run till the battery gives up. Never had a problem.
The only problem I've ever had as far as a corrupt file was when a card was popped out as it was being recorded to.
Other than that, never had an issue with a corrupt file when the battery dies during a time-lapse.
So two questions:
How long did your battery last? And was your screen closed/off?
Repair the file: Can you elaborate on how to repair a file? But it sounds like from n8ture it won't be corrupt.
thanks
