kenackr
The DVX 100B manual shows output comes in 3 forms: S video, Composite, and Fire Wire out with a DV codec in SD format. The DV codec compresses the signal among other things, I believe.
I understand that uncompressed signal is much higher quality. Is there any way to get an uncompressed output signal in some fashion from the DVX 100B ? If one wants to capture direct to disk for location shoots? I could find nothing in the manual or in Barry Green's DVX book or search on the subject here.
Or if that is not possible, is there any way to get a component signal out?
Or if that is not possible, is there any type of a converter for either the Fire wire out or the S video out that will provide a standard SD output?
In case you're wondering what I'm trying to do, there are two things driving me in this direction:
1) I'd like to mount either a 7" or 8" monitor to the camera that has high resolution and the ability to perform other checks when setting up a shot, focus, iris, luminance, etc. The ones I've looked at basically take only composite & Hdmi. Higher end monitors also can take component.
Any help would be appreciated,
Ken :embarasse
- Is it normal for people to use the S Video out for on cam monitor use? If so, doesn't that degrade the monitor presentation?
[*=1]In this scenario, the MBP non glare screen has resolution up to 1920 x 1200 native, but I'll have to find out more about about color representation (I do have a Spyder Pro Color calibrator).
[*=1]It would also be nice if I were able to tweak the video & audio being captured with something like a Motu V4HD which accepts both Audio & Video and can also convert to Pro Res 4.2.2 (and many other codecs) instead of DV.
Ken :embarasse
