Hummm. Soft light require to be close to your subject and has big as possible...dimension of the light source and distance from the subject determines if it's hard or soft. The bigger and closer to the subject, the softer it will be.
I don't think that's true... if anything, the opposite.
No no no...the bigger the source relative to the subject is, the softer it will be.I don't think that's true... if anything, the opposite. Soft light does not require to be close to the subject - if anything, being further away can make it softer. The problem with soft lights is that sources of soft light fall off very quickly with distance, so for practical reasons need to be brought closer, but that has nothing to do with softness/hardness, it has to do with the brightness of the source. And bigger lights are not softer by nature - softness has to do with how the light rays are dispersing and propagating, not with size - you can have very large brutes that throw a large hard light. Again, for practical reasons, we use large surfaces to disperse the light to make it softer, but that's again down to the source.
Wrong.
Consider a 1X1 - it is about the height of a face/neck.
At one foot away it is a 'soft' source
Move it back to 10ft away and it basically becomes a spot/hard source
S
You're confusing softness and intensity.I don't think that's true... if anything, the opposite. Soft light does not require to be close to the subject - if anything, being further away can make it softer.
Yet, I stand by my point...the bigger the light source is relative to a subject, the softer it will be.Well, I didn't mean it literally - that's why I said "if anything"... but in practical terms, it's hard to keep light rays perfectly parallel as in a laser, so you'll get it "mostly" parallel, and therefore "hard", but if you move it over a distance, then the small discrepancies will become exaggerated, so the trajectories will start to diverge and that's how you'll get softer (in addition to less intense of course) light. It's a small effect, but it's there.
