Hi
I'm working on my first low budget feature with my HMC151 and I have hit a major problem already.
I brought in willing actors and actresses to a location I hired recently. Shot day one of a three day shoot on Transcend 16GB SDHC cards - no problems, footage looks great.
Day two started off really well with a fresh 16GB card from the same manufacturer. Shot some nice looking footage throughout the day, played back a few clips for us to review. Switched HMC off whilst we set up for the next shot, switched camera back on (using same Panasonic high capacity battery) and we had a 'Check Card' message. Took card out, reinserted several times investigated to make sure the little lock had not been partially set - but the camera gave the same message each time.
Tried not to panic in front of about 20 people. I swapped the card for another 16GB card and carried on - again no problems, footage looks great, able to review clips etc
When I eventually got home I was able to copy data off several cards and back them up to two different spare hard drives (plus I spread the clips including folder structure across lots of DVD's just in case).
However, the 'rogue' card is invisible to the PC (and camera). I contacted Transcend and they suggested I first download free software (some have been mentioned on this forum) to test first. I did but again nothing including programs like Recuva can see anything on the card. I know that material was on there because several of us actually watched the clips.
Transcend said that if this does not work then send the card to them for further investigation. That worries me - what if the company don't even bother to check properly and for ease just send out a free replacement card (or am I being paranoid?)
My 6 new Transcend 16GB cards had all previously been recorded over from beginning to end with no problems (after formatting in camera first). I also took advice from these forums and deleted all clips rather than reformat.
Firstly do any of you know if Transcend have proper recovery labs?
From the symptoms I'm experiencing it seems that I have a physical problem with one card and there are companies out there who boast that they can recover data under the circumstances. They do this by taking the guts of the card away from the contacts and copy the data straight off the board in a special reader apparently. This is expensive but cheaper than bringing everyone back (and in the process losing face with the cast - it may look like I was totally incompetent).
However, I am now wondering if it is actually the card that is at fault or the camera. Here's why:
I noticed that on location, if I stopped recording and left the camera alone for a while then tried to play the material back, it took a long time to switch into play mode. My cards are all fairly full at the moment and each time I press play it can take up to FOUR minutes to get anything to play. Is this because I have so much on the card that a buffer cannot cope? If this is not normal, then perhaps the camera is faulty.
So secondly, please can anyone with lots of material on a 16GB card tell me how long it takes the camera to get in to play back mode? When I captured material on previous shoots I never filled the cards up to any where near capacity so I did not experience any real lag when playing back clips.
Thank you
Paul
Thank you
Paul
