Please help? Question about 720/24pn and firestore?
HPX170Guy
So i know i cant record directly to the firestore in 720/24pn....if i want to do this i have to set the camera to 720/24p and then go into VFR mode and set that to 24p...
correct? and this will record my content in 720/24pn?
well first if you can tell me if im correct on the above comment...
next is when i did this my firestore did record but it said AUDIO MUTE on my firestore display? obviously that means im recording but with no audio...anybody know what i need to do in this situation...
doing a shoot tomorrow and want to shoot in native format so any info you guys can provide would be GREATLY appreciate...thanks guys!
FS-100 250GB
version 4.0.1
To record in PN on the Firestore, you have to set the camera to 720P/24P, this will produce 24P over 60 frames. The Firestore will see this signal and strip out the extra frames. You do have to have the firestore set-up properly.
Hope this helps,
Jan
thank you jan, got it :)
i actually have to put the code on the firestore to quicktime pn as well, and chance change the recording setup in the camera to frame rate as well...
thanks again
Hope this helps,
Jan
what about in1080i/24p? or 30p?
