PLEASE HELP! Project due in 12 Hours!
Dangit - what a time trying to learn software!
Thank you all who have helped me with the slow motion.
I am now having Publishing issues.
My goal - take my beautiful sequence in FCP 6 and burn it to a DVD.
Taken and imported in 1080i60 16x9 - only 6 minutes in duration.
How to I obtain the video quality the same or near same on the Final Cut Pro preview?!
I only have iDVD to publish to (unless someone else has an idea (don't have dvd studio pro :( )
I have fast motion of a motorcycle - I have freeze frames when it passes by a scale beam to read angles. In all my exports (quicktime current settings / quicktime hdv 1080i60 / quicktime DV NTSC) it makes them all jagged and double framed.
Also all the exports have the interlaced line appearance!
How do I export to what file/compression and mount to a DVD with iDVD to obtain the same or near quality that previews on FCP that will be viewed on a projection screen in a class room?
Any help with be much much MUCH appreciated!
Jason!
Go in IDVD, and add in the file. Try going into the settings and change it to progressive. And the footage would be interlaced seeing as you shot it interlaced.
Thanks Matty! I relayed the message - I've been pulling my hair out trying to help my friend with his project - we figured it out tonight - he exported it out to the HDV 1080i60 quicktime and drag dropped it into iDVD - and selected burn - came out pretty good for SD.
C.M. it's my friend's computer - I'm was helping him the best I knew how from when I helped him create with my imovie hd - he wanted to try FCP.. ugh what headache it was... ah.. relief ... was..
Thanks for the help!
