plastic green screen material
zoob
I know fabric or linoleum is probably best for a large DIY green screen but I've found some plastic table cloths (green, brown, tan, etc.) that have a slight sheen and are folded up. Is there any particular way get the wrinkles out of plastic? Can I iron plastic together?
That sheen will make you tear your hair out.
I own several cheap eBay fabric screens and they're great. I've had them scoped at the paint store for green paint which also keys like a dream.
Yeah, you don't want reflective material. That's why muslin or matte paint is preferred. Reflective surfaces will show up white in patches and not key well. There are plenty of cheap muslins on ebay. I got a 10'x20' one for under $40 delivered.
I've got about 8 eBay screens. The next thing you buy is generally a fabric steamer... I have a big wardrobe-dept. model, and recently got a little handheld job.
I'm going to try some of that foam material next... you can assign a grip to steam a screen for an hour and still not kill the wrinkles.
The ultimate is a painted wall though, or a cyc.
I'm now leaning towards a large pre-made green screen rather than all the effort needed to make my own.
Reading reviews now but would appreciate any additional info.
Well I have this Green Screen by Wescot, it's made of fleece material, it really works well, No reflection, No creasing, has a slight stretch to it. very consistent color. I fold it up into a fleece bag that it comes with and when I pull it out to use it again, it looks perfect, just a little stretch and it's ready to use. http://www.fjwestcott.com/backgrounds/chroma-key/9-x-10-wrinkle-resistant-green-screen-background
Wescot has nice products.
Check out the Botero collapsable screens. I have the 8'x16' and it's a decently big size when expanded, and really convenient to cart around when collapsed.
I've used those cheap, vinyl picnic table covers many times and never had a problem as long as the lighting is right. Don't point lights directly at it, or it will reflect. Best used with overhead lights that are pointing straight down. Standard subject lighting applies. I also find a lot depends on what software you're using to key out the green. Some things work great with Final Cut, others are better with Adobe.
I've tried many kinds of greenscreens, including the "chromatte" one that is an expensive, reflective material that requires a colored ring light attached around the lens of your camera. The light bounces off tiny glass beads in the material. It works great, but I've also gotten very similar results using a DIY ring light and reflective safety material.
For your wrinkles, why not just add weights at the bottom, or use duct table to tightly affix it to the wall or whatever you're shooting on?
