[FS: General] Planar PD8130 DLP HD Projector for Home Theater
Status
Not open for further replies.
SergeSmArt
I have this DLP Projector for sale on E-bay for people who are able to coming to my place in Brooklyn and take it!
Here is E-Bay link:
http://www.ebay.com/itm/121197588255?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
Planar PD8130 DLP Projector
for Home Theater
The PD8130 is a relatively large DLP projector. it's 530mm X 455mm X 200mm
The case has a very elegant, piano black finish as you can see on pictures...
IMG_1954.jpg Planar.jpg Planar_2.jpg Planar-Projector.jpg Projector_placement.jpg RearPanel.jpg RemoteControl.jpg zoom_video37-Planar-menu2.jpg
Have a removable hood that covers the rear input panel for a cleaner, curvy aesthetic.
The light path is completely sealed and eliminates the fear of dust getting into the optical path or light loss from the chassis.
The PD8130 features an all-glass manually operated ZOOM LENS with a relatively flexible zoom range that accommodates longer throw lengths.
Specification:
Projector type DLP projector - High Definition 1080p
Features Motion Adaptive Progressive Scan,
High-bandwidth Digital Content Protection System (HDCP),
3D digital noise reduction (DNR)
Display:
Image Brightness1000.0 ANSI lumens
Image Contrast Ratio10000:1
Throw Ratio 1.85 -2.4:1
Uniformity 90.0 %
Resolution 1920 x1080
Native Aspect Ratio Widescreen 16:9
Max Sync Rate (VxH) 85.0 Hz x 90.0 KHz
Lens:
Focus Type: Manual, Lens Aperture: F/2.5-2.71
Zoom Factor: 1.3x Lens Shift Direction
Vertical Shift 100% / 120
Video Input: Analog Video Format PAL-I, SECAM-M, M-NTSC, SECAM, PAL-N,NTSC 4.43, PAL-B/G, PAL-M, PAL-H
Expansion / Connectivity:
Interfaces 1.0xS-video input - 19 pin HDMI Type A X 3 ( Management ),
1.0 x Composite video input - 9 pin D-Sub (DB-9),
2.0 x VGA input -Mini-phone 3.5 mm,
1.0 x SerialRS-232 - RCA,
2.0 x Audio line-in - 15 pin HD D-Sub (HD-15),
1.0 x HDMI input -RCA,
1.0 x Component video input - Mini-phone 3.5 mm,
1.0 x Remote control input - 4 pin mini-DIN
THIS PROJECTOR REQUIRE LARGE ROOM - AT LIST 25' LONG, TO GET IMAGE TO FIT LARGE SCREEN !
( Unfortunately I don't have a big room to use it... )
I use it in "ECONOMY" mode only, because in my small room it produce more than enough brightness!
The Lamp in Economy Mode have 4000 hours life time, but since I have it, - it used ONLY 100 hours!!!
-You are able to check in in Projector Menu!
NOTE: THIS LISTING ONLY FOR PEOPLE WHO ARE ABLE TO COME TO MY PLACE IN BROOKLYN, NY, 11204 - TO PICK UP PROJECTOR PERSONALLY!
Status
