pixel aspect ratio question
deadmike
i was wondering if i will run into any problems exporting hvx 720p clips from final cut with square pixels instead of 1 to 1.3 or whatever it is natively. the reason i ask is i am working on an animation project mostly constructed in after effects in 720p with square pixels. then i will be exporting files back out of after effects to edit in final cut. will this work with square pixels? also, even if this does work, will i run into wierd noise or aliasing problems because of the ratio conversion?
finally, when exporting from final cut to after effects should i leave it dvcprohd or uncompressed. i would like to leave it compressed to save hard drive space because this is a 45 minute film. then when going from after effects back to final cut would dvcprohd be the best codec to edit with for realtime playback?
i apologize if this post is confusing. thank you much for any help.
It is square pixels natively. The HVX creates a 1280x720 resolution pictures in 720p mode, which is a square pixel ratio. It will composite seemlessly with your 720p After Effects animation. All of the DVCPROHD formats that the HVX200 uses are all square pixels (whether we are talking 720 or 1080).
Also, I would render it out as DVCPROHD personally, not as uncompressed.
DVCPRO HD does not use square pixel aspect ratio.
That would mean the formats would be 1280x720 and 1920x1080, instead they are 960x720 and 1280x1080 / 1440x1080.
If you export in the native format from FCP (DVCPRO HD) it will be rescaled on input to AE to square pixels automatically by Quicktime.
Unless you are going to output to DVCPRO HD tape in the end, I would render from AE in both 1280x720 Animation codec and as 720x480 DV PAL.
It's very easy to setup the render queue so you get dual output and it will not slow down that much.
This way you can edit in FCP using the realtime DV version, and then relink to the HD files when you reach final cut off your film. I have done this a few times myself and work well. Just keep the files organized and be sure that the HD and SD files bears the same unique name.
When you do a computer animated project it would be a bad thing to go from 1280x720 4:4:4 RGB that AE deliver to 960x720 4:2:2 YUV of DVCPRO HD. The Animation codec is Uncompressed RLE 4:4:4 RGB.
thanks for the info. i did not experience any automatic ratio conversion when i brought the quicktime files into after effects. i had to set final cut to render square pixels. this is not a problem though. also i have not tried dual render output from after effects. sure i can figure it out though. also why did you say i should output PAL dv?
now if i'm not working on an animation project, but just with camera footage that i am tweaking after effects, should i keep it all dvcpro with the original pixel ratio?
also, by chance do you know roughly how much larger animation codec file sizes will be than the cameras 720pn( i know my computer can't playback animation codec realtime, at least off my main harddrive). trying to decide between a 320gb or a 500gb g-raid.
thank you much.
