PINK FUZZ! Help Importing from copied Disc Images!
JoshuaOne
Copied Contents and Text File from Disc Images on P2 Store to local Mac HD.
Now when I attempt to import via P2 I see good thumbnails, but crazy multi-colored pink static fuzz, instead of my clips - The Clips (obviously) don't playback in the viewer - and when I attempt to process a clip it crashes FCP. Tried copying Disc Images (folders) to a FW drive and still no luck.
Running. FCP 4.1
OS X 10.4.9
Pro App. 4.0
I follow this process routinely on other macs and my laptop.
Any suggestions?
-JoshuaOne
I don't mean to scare you but it doesn't sound good.
Usually that static multicolored stuff means that it's a corrupted clip.
From my "P2 school of hard knocks" experience and research done here on dvxuser, this can happen when there is an interrupted power supply to the p2 media being written (sometimes a dying battery or a loose 3rd party battery attached to the P2 store as what happened with me). Unfortunately, I haven't found any way to recover the data yet.
Good Luck!
Philip
