aravance said:If you are very serious with your work...why would you settle for a "normal movie mode" option anyway?.
Jbadham77 said:Because I don't want to take a whole lot of time on the set messin' with it...
I want to just set it to best quality "like that" *clicks fingers AKA, switches to movie mode*
Mack Fisher said:mabye you should try something like the HC3 from sony. it has a faux progessive mode called cineframe, its a good out of box camera I guess. But the DVX100B isnt for someone who just wants to grab it and spend no time on settings or learning about the camera and just shoot.
Jbadham77 said:But it has the quality I need...
filmamigo said:It's like any professional tool.
Surely, if you bought a lathe, you wouldn't expect the lathe to make you into a master machinist?
The DVX100 has lots of automatic features and presets that can, when used judiciously, make life a little easier. On the whole, you should turn them all off and learn how to control every aspect of the camera yourself.
If you feel that you are too busy/uninterested/impatient to do that yourself, then hire a DP. It's the job of the DP to know EXACTLY how an image is formed on the camera at hand, and how to manipulate the camera to get the desired look.
There is no "best look" or "best setting". It's not an either-or question. There are thousands of "looks" -- to find a look you like, you can reference Hollywood films, or great painters, or home movies, whatever you like. The knowledge of how to achieve those looks is hard-won. Almost every camera setting can be part of that equation.
Like a lathe or a milling machine, your DVX has the power and control to completely wreck what you are trying to produce. You can make an ugly image, you can ruin your audio, you can even fry your microphones. If you would rather not have the ability to wreck things, then buy a camera with less control:
http://www.sonystyle.com/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/USD/SY_DisplayProductInformation-Start?ProductSKU=HDRHC3
