rawfa said:If you only need 60i and progressive does not interest youm I would go with the pd-170. But have in mind that with that money you could buy a ag-dvx100 or a FX1.
vincent_price said:just buy another dvx100...
Policar said:In interlace mode, the DVX does better in ultra low light than it does in progressive mode so consider that a valid option. The PD150 has less punch to its image, but even with +12db of gain it is very useable and certainly looks better than the DVX, although you lose color saturation. The DVX is a lot more fun, of course.
IMO, get a VX2100. Unless you desperately need XLR inputs, it should be perfect. Very inexpensive and better low light performance than any other consumer cam (except the PD170, which uses the same chips.)
rawfa said:Kmcgrath, if the big issue here is low light performance at 60i, I would choose the VX2100 and buy a beachtek XLR adapter (150 bucks?). But, once again, the dvx and the vx produce very different footage. If you're a master of CC you'll probably be able to match them, but I would not take the chance.
