PC card adaptor for desktop
pgovotsos
Can anyone recommend a PC Card adaptor (with source and lnik if possible) for a desktop computer that is P2 compatible? I use them just fine on the laptop, but the desktop is where the editing horsepower is.
What specific computer with what specific OS are you using?
When you state that you "use them just fine on the laptop," what are "they" and what laptop with what OS are you referring to?
Sorry, "them" is the P2 cards. The desktop & laptop are Win XP.
Ideally, I'm looking for an adaptor that will allow me to use PC cards from the front of the machine (something that fits in a drive bay for example) instead of the back. I saw a couple on newegg, but they were all accessed from the rear of the machine. It;s difficult to use that when the machine is under the desk.
Panagiotis
I installed one of these. Works fine.
http://www.shopdigi.com/product.aspx?pf_id=P2PCI
Get about 2 GB/min offload.
Keep in mind that you'll have to update the P2 drivers to recognize it.
I read the info:
" Product Detail
PCC01 is a high-performance PCI-to-PC Card Drive Unit that supports one independent card socket compliant with the 16/32-bit PC Card standard defined in 1997 PC Card Standard.
Povides a rich feature set that makes it the best choice for bridging between PCI and PC Card in desktop computers.
Compliant with the 16-bit PC Card specification defines in PCMCIA Release 2.1 and JEIDA 4.2 and can supports any combination of 16-bit or 32-bit PC Card in the one socket, powered at 5V or 3.3V as required.
The host system interface of PCC01 is compliant with the PCI Local Bus specification 2.2.
PCC01 is register set compatible with Intel 82365SL controller and compatible with ExCA, it enables the PCC01 to support almost all of the PC Card applications including: SRAM card, Linear Flash card, ATA Flash card, Modem card and Wireless 3G/Modem/LAN card.(Panasonic P2 Card; recommended for the Dexis Digital X-Ray System) "
Can you tellme what does this mean?:
Thnx
Hi Ernesto,
if your cutting on a windows box , you'll be fine to get one of these readers, if your on Mac, don't do it.
Cheers
Tom K
