[FS: General] Paralinx Arrow-X Receiver (Receiver ONLY, with AB plate and post) - $1,800.00 + Ship
sukram
Selling one of my three Paralinx Arrow-X Receivers. Can be matched to any Paralinx Arrow-X transmitter (up to four receivers). Includes an AB female plate, and metal support plate. Two 3G SDI outputs. Barely used. Normally retails new for $2,700 plus tax/shipping. Serial numbers shown in pics.
Selling for $1,800 USD plus shipping. Please contact by email: mrbogata@gmail.com
The Paralinx Arrow-X System is a revolutionary HD Video Transmission system offering Realtime Wireless HD with robust long range for your Television, Film, Broadcast, Industrial or UAV/UAS application.
The Paralinx Arrow-X transmits full-HD 1080p/60 with a range of up to 700 feet (215m) with default antennas (longer range possible with optional antennas) and still maintains an incredible sub 1ms latency glass-to-glass.
The Arrow-X receiver features 2-Pin Lemo power connectors capable of a wide 7-17V unregulated input voltage and dual 3G-SDI video outputs.
Much like the popular Paralinx Tomahawk, the Arrow-X transmits Full-HD video (up to 1080p/60 4:2:2) with less than 1 millisecond delay and is capable of handling up to 4 simultaneous receivers. The receiver weighs 12 oz/340g (without antennas).
Arrow-X receivers can be purchased for MSRP US$2,499.95 each. Battery plate, antenna, mounting, power cable, and case options are available as accessories.
Arrow-X Receiver Features:
Lightweight Minimalist design for reduced payload
Dual 3G-SDI outputs
Rugged ABS enclosure
Long-range transmission - Up to 700 feet (215 meters) *
REAL-TIME viewing - Less than 1 millisecond latency
Uncompressed full-HD video signal allow critically accurate monitoring
Multicast capable (up to 4 receivers per transmitter)
128 bit AES Encryption - Secure transmissionpost-68968-0-23578200-1446408908.jpgpost-68968-0-25035500-1446408921.jpgpost-68968-0-95575700-1446408928.jpg
Operates on 5gHz frequency band
Conforms to major technical and environmental standards including FCC, CE, MIC (TELEC) and RoHS Specifications
* Range may vary depending on environment and interference
Dimensions (US): 5" x 5.6" x 1.3" (not including antennas)
Dimensions (EU): 143mm x 128mm x 33mm
Weight: 12oz / 340g (without antennas)
