bgundu
I'm sorry to say Brad but the 7D also records to the cards as 4:2:0. The jury is out on wether you can get 4:2:2 through the HDMI or not. But the AF100 can output 4:2:2 through HDMI and HD-SDI.
(Actually, I wasn't sure if you were implying that the 7D can record in higher color space or not. Sorry if you're not)
I too only work virtually on the native files of my DSLR, in Premiere and in After Effects and then I only master to TGA, no compression to deal with and the only compression was in the original. Your post route is wrong if you're downsizing the resolution of the master and recompressing. You've got to think about that. If you can work on the originals, work on the originals.
The AF100 is an interesting camera, 4:2:0, variable fps, interchangable lenses. Not for me. I want to use a higher color resolution and until then I'll use the 7D.
