Bassman2003
Thanks. I have found the two controllers I have, a Libec and a Manfrotto work reasonably well but the stepping in between speeds can use some work. I am assuming it is from the camera side, not the controller.
Yes, this is another step backward in usability from previous cameras like the DVX200 and UX180. With earlier cameras you could use the thumb wheel to adjust the gain in 1 dB increments, but with the CX350, gain is not one of the settings that is directly adjustable via the wheel (this is called the Multi Manual function in the user's guide).
It is possible to adjust the gain on the CX350 in 1 dB steps, but you have to go into the [SW MODE] section of the CAMERA menu and change the gain level that is assigned to the L, M, or H settings of the physical gain switch. Which is not really a convenient way to adjust the gain. And often you may just want to make a temporary gain adjustment for what you are currently shooting, but changing the gain via the menu like this means that the physical gain switch will now keep this new gain setting indefinitely (at least until you go back into the menu to change it to something else).
I am finding the auto iris tends to overexpose. Filming some outdoor sunny day football games, I flipped on auto iris and had to turn the compensation down to -12 to get a good exposure (through the viewfinder). Just plain gets it wrong a lot. My PX270 never missed very much with auto iris.
Thanks for the heads up. I installed the update and am happy to find 720p60 options! Checked the remote zoom behavior and it is still the same, kind of clunky. I am going to try to contact Panasonic about this as it is too touchy moving from creep to slow speeds.
Is the new 100Mbps HEVC 4k format 4:2:2?
I don't know Mitch. I have two of the most expensive LANC controllers, one from Libec and one from Manfrotto and the zoom action is not up to professional standards imho. The jump from creep to slow to mild fast is too close and jumpy. Now if the best to controllers do not work with a pro camera, then are we supposed to use the cheap ones? I believe there is more work to be done inside the camera. BTW, this has stopped me from replacing PX270s as they are performing better. I e-mailed Steve Cooperman about this and never heard back. I just can't fuly adopt the cameras without proper rear zoom behavior.
One thing you might want to check regarding the zoom speed progression is using the CX ROP app (on iOS or Android). When I looked into this earlier, the same 8 zoom speed levels that were being used in response to LANC commands were also used in the zoom speed control section of the app. Although the app uses a different XML-based protocol to talk to the camera, it also has 8 zoom speed settings just like LANC does. The app has a slider for zoom control, but if you carefully slide along the range you'll notice that there are actually 8 distinct zoom in and 8 zoom out positions, corresponding to the different zoom speeds.I don't know Mitch. I have two of the most expensive LANC controllers, one from Libec and one from Manfrotto and the zoom action is not up to professional standards imho. The jump from creep to slow to mild fast is too close and jumpy. Now if the best to controllers do not work with a pro camera, then are we supposed to use the cheap ones? I believe there is more work to be done inside the camera. BTW, this has stopped me from replacing PX270s as they are performing better. I e-mailed Steve Cooperman about this and never heard back. I just can't fuly adopt the cameras without proper rear zoom behavior.
