[FS: General] Panasonic Varicam 27H
Rocketeer
Clearing out the shelves.
Varicam 27H with VF Gadgets heavy duty handle.
OP 2130 Hrs
Drum 1640 Hrs
Due for a head change shortly according to Panasonic but is in full operating and recording condition and the block is clean.
Priced to go US$9000
HDC27H improvements over the HDC27F include (but are not limited to):
* An updated optical block results in greater sensitivity in the blue channel, thus reducing overall noise.
* 12-bit DSPs instead of 10-bit in the Model F, which decreases noise and increases dynamic range
* Dark compression mode - allocates more bits to dark areas of frame – especially good for Film Rec shoots where there is a lot of detail down there (also available in latest Model F upgrade, but not really useful in F since the setting would reset at each power down).
* The rear HD-SDI connector is a clean feed (no characters).
* It is now possible to output frame-lines from the side HD-SDI connector.
* Lens flare settings are now saved as part of the lens files.
* White shading info can now be saved to an SD card for later recall.
* New option to delay audio to maintain sync at 24fps.
* Slightly less power consumption of the Model H vs. the F (36W vs. 39W).
* Automatic pixel compensation on black balance.
* Manufactured with lead-free solder.
* Refined cooling system.
