Bruce Watson
If so, then why would Panasonic bother making a 2/3" 4K chip, if it will never be an optimal sized sensor?
Depends on how you define "optimal" doesn't it?
I suspect they'll work on 2/3" chips because of the huge acceptance of the 2/3" equipment in the broadcast industry. If they can make 4k work acceptably in a 2/3" chip format, they can more easily maintain their user base, and their vendor base. IOW, all the 2/3" lenses still work. Cameras still shoulder mount as before, operators still uses them as before, etc.
If they try to go to a bigger chip size, they also have to make everything else bigger, especially lenses. Which makes the lenses cost more, makes the cameras cost more, make the cameras heavier to support the heavier lenses, and pulls the weight balance toward the front. None of these things will win much favor with the on-the-shoulder users.
Then you factor in the decrease in DOF as they go to bigger chips, and the ENG crowd might start to rebel outright.
So I can see why they might just want to find a way to cram 4k resolution into the 2/3" chip form factor.
