Panasonic Tapes
greeches
Can i use MQ,PQ, and the lesser Panny tapes safely? Are the lubes different, and if so, will they cause a problem?
Re: Panasonic Tapes
There has been a lot of discussion on tapes, but it all seems to boil down to this.
-Don't mix brands, stick with one tape.
-Good tape is cheap, why take chances.
-You have a $3000+ cam for a reason - you want the best quality, use quality tape.
-People selling a used DVX will advertise 'Only MQ tape used" as a selling point for good reason.
I do not know if lesser quality panny tapes are 'unsafe', and I will never know in this camera of mine ;)
Umm, I guess never is a strong word. If MQs went to $20+ I might consider something else..
Re: Panasonic Tapes
MQ is definietely better...but if u really need you can mix PQ and MQ...as both are dry lube.
Re: Panasonic Tapes
I bought a 100A camera recently and ran off to shoot and without thinking about tape stock too much, I just bought what I had always used with my pd150 -- Sony DVCam tape.
Then in doing some research on the camera it became clear to me that there are some issues with the differenct manufacturers and the tapes they produce being wet or dry etc.
If i started using the Sony dvcam tapes, should i just stick with them? Or should i switch to the panasonic MQ? or should i have the heads cleaned and then switch to MQ?
Re: Panasonic Tapes
kerthyfix,
I guess no one with the answer to your question saw this (your first) post. I have my own opinion on the subject, but you'd rather have an expert. Try posting a new thread. You could get a great answer or several pretty good answers to choose from ;)
Welcome the forum!!!!!!
