Panasonic P2 footage looks bad
markchant
Hi
I have recently been left a panasonic hpx3000 and have decided to keep it and try and learn how to use it
when I record footage and view back on the built in screen the footage looks great, but when I import it to the pc and convert it it looks very pixelated
and not clear at all
Iam using Iorgsoft to convert it could it be my graphics card ?
It's probably iOrgSoft. I've never heard of that software package, and the HPX3000 is a terrific a camera. You need to get something higher-end to work with the footage, such as Vegas, Edius, or Premiere.
Unless you are recording in a SD format and trying to view the results on a HD display, the problem is undoubtedly in the iOrgsoft conversion. I had also never heard of them so I did a bit of searching and the objective (not planted) reviews were not good at all.
Get a good NLE that understands AVC-Intra natively, and use that to edit and output in whatever format you want / need.
If you don't have the budget for good editing software and a PC to support it, I'd sell the camera and get something less complicated, and put some of the proceeds towards the editing end of the equation.
When I look at the footage straight out the p2 card using the viewer it can look very blocky. It was quite disconcerting the first time. Looks the same when I zoom in in Premier Pro (I use the older CS4) but render it and it looks fantastic. Not in the slightest bit blocky. I may be wrong, I never asked the question because I was happy with the final result, but I just assumed that the camera saves it in a format that is optimised for later rendering. It may also depend on the format you record in. I only use one format 720p24pN which I'm pretty sure is a DVCPRO (24pN) only mode from memory. Not 100% sure because I haven't changed it since I set it up.
What NLE do you plan to edit in? You should choose one that is compatible with footage as it's easy to edit with already, no transcoding required.
Thought it may have been the iorgsoft convertor
what convertor would you recommend and Thanks for the help
First of all, you want P2 Viewer from Panasonic (free download). Make sure you get the version which reads AVC-Intra.
And, as others have said, you shouldn't be converting the footage at all. You should be using an editing program which uses the footage natively.
The HPX3000 is a top-of-the-line camera (you got it for free?), so its footage is exquisite when shot properly.
