tokun1
Hello Group,
I'm coming from a camcorder background for many years, I just recently purchased my first DSLR (Lumix gh5) 2 weeks ago. The focusing has me completely stumped. I'm using the Panasonic Leica 12-60mm lens, I have the camera on Manual everything, I use the focus ring to focus in on an object to do a rack focus of an object in the foreground, and for some reason the focus keeps changing on me slightly as I pull from one object to another. I have to pull a little bit farther, or less of a pull. This is baffling!..., the camera is locked down, the lens is locked in and set to manual and the stabilizer is turned "off", the aperture, frame rate, and Iso is set, nothing is moving, the tripod is locked down tight. At first I thought is was the follow focus ring, that is was slipping, when I removed the follow focus ring, same issue.
I would greatly appreciate some help as to why this is going on or what I'm doing incorrectly. I'm missing my camcorder about now with my fixed lens.
Thank you!
-Tony
Thank you!
-Tony
