Panasonic LH1700 displaying jagged lines???
I just a purchased a Panasonic BTLH1700 to use as a braodcast monitor with Final Cut Pro 6 and even though the monitor and my FCP project are 720p mode, I'm still seeing jagged lines. I thought that was usually a 480i issue.
When you're working in a 720p project, should you be seeing jagged lines as in interlacing on the Panasonic LH1700???
Please help. Thanks very much in advance,
- Nicholas
PS: The monitor is connected to my computer via component cables and a BlackMagic HD Pro card. Should I be looking instead at Matrox MXO???
The LH1700 has both SDI and Component interfaces. Your Decklink card has SDI out. Connect SDI cable from Decklink to the LH1700 and just make certain the input is set to SDI.
Ned
