Hello Listers
For Sale is a Panasonic HMC-40. This is the little camera that can. This cam produces a full-raster 1080p image. In a form significantly smaller than a HPX170 or AC90, this has real cam features such as a wave form monitor, zebras, scene files, 3 1/4" mos sensor and more and records to AVCHD. This cam is pretty well known so I won't go into too much detail except to say if you want a very sharp cam that has pro audio features and is exceeding light and compact, you might want to consider this.
Everything works perfectly, there is just a small bit of wear on the body, but no dents or damage. I am the original owner and have used this as a B-Cam to a HPX170 which can be made a close match be working on the scene files. Though the HMC40 is somewhat sharper than the HPX - HVX cams.
Included with the cam are the following:
Panasonic AG-MYA30G Audio Interface - Detachable with the handle if you want more sleek
Panasonic VW-W4307H Wide Angle Lens - Gives you about a 28mm equivalent with barely any vignette
B+W 43mm .09 ND Filter
B+W 43mm Circular Polarizer
Panasonic Original Equipment: Charger, Battery Eliminator, Remote Control, Lens Hood and Cover
Panasonic Original Battery and one High Capacity No Name. Both work fine
SanDisk SD cards: 2ea 4GB and 1ea 8GB
Vello Hood for the flip-out
Original Boxes for Camera, Lens and Audio Interface
$900 Shipping and PayPal included, CONUS only please
Best to email me, Grant Gormley direct: visualservices@mac.com
