[FS: General] Panasonic dvc30 3ccd cam + extras $1500
deezy73
SELLING MY FAV CAM AND SETUP THIS IS AN EXCELLENT CAMERA ONLY USED 159 HRS!!! PLUS I AM INCLUDING AN ANTON BAUER ELIPZ AND ELIGHTZ LIGHT AND BATTERY KIT PLUS A RAYNOX WIDE ANGLE LENS.....THIS IS AN AMAZING DEALIMG_0346.jpgIMG_0351.jpgIMG_0353.jpgIMG_0354.jpgPRODUCT FEATURES:World's first professional DV camcorder with Infrared recording mode that can record in zero footcandles;4 Scene Files featuring control of professional functions: Detail, Chroma Level, Chroma Phase, Color Temp, Master Ped, AE Shift, Skin Tone Detail;Movie Like mode combines frame mode & CineGamma for a cinematic look;Slow-shutter function for motion lag effects and increased sensitivity;Newly developed wide-angle, extraordinarily quiet, 16x high speed optical zoom Leica Dicomar lens with low-dispersion glass reducing chromatic aberration & flare with OIS (Optical Image Stabilizer);Very wide range of Zoom speed fast 1 second (sports);410, 000-pixel (380, 000 active pixel) 1/4-inch 3-CCD for class leading picture quality and sensitivity;12 bit A/D converter and RGB gamma processor assure high image quality;Date & Time stamp can record in the picture area;Removable handle (incl.) and XLR Audio input module (opt.) allows for customized shooting style;Enriched Auto Functions: Auto Focus, Auto White Balance and Automatic motorized Neutral Density;Lightweight (2.4 lbs.) and well balanced.Includes:- Panasonic AG-DVC 30- 1 Panasonic Battery-Users manual- Battery Charger - Remote controlAnton Bauer ElightZ, 6 volt Professional On-camera Fill Light with 10 watt LampElightZ is the first professional on-camera light designed specifically for handheld cameras. Operating at 6 volts, the same as the camera, ElightZ shares power with the ElipZ 10k battery through its exclusive Powerplug connector. Constructed of lightweight and durable high temperature polycarbonate, the two-stage hinged boom arms of the ElightZ offer a virtually unlimited range of adjustability - fully extended, the head is over 5 inches high and can be extended forward to eliminate lens shadowing. ElightZ high efficiency 10 watt halogen light packs photometric performance to blend almost any available light. The light head bezel removes easily for bulb changes. The bezel also features two mounting points for a wide variety of gels and spun (included) to effortlessly adapt to any lighting conditions. ElightZ mounts quickly and easily to any camera mounting type - shoe or stud - with a unique modular mounting mechanism. Best of all at the end of a shooting day, the light folds away neatly into a compact package and can remain on the camera without adding weight or interfering with camera operation.
