Avenger007
For Sale:
Panasonic BT-LH900A HD Monitor
Purchased as a backup for second unit work on a recent film. Used for a couple of focus tests in house and thats it. Like new condition, in the original box with original packaging and accessories.
PRICE: $3850 Shipped (extra cost for shipping outside the U.S.)
Paypal preferred.
Pictures uploading this evening. Further Specs:
The BT-LH900A is equipped with two SDI inputs automatically detecting HD or SD, one component input (Y/Pb/Pr or RGBS), and one composite input. The new Video/CineGamma Conversion Table and built-in waveform monitor function support HD production when using the popular Panasonic VariCam HD Cinema Camera. It easily mounts atop the VariCam and other cameras as well. Also convenient is the separate control panel that can be mounted on the top, side, or bottom of the monitor. Designed for side-by-side rack mounting (optional) and equipped with both DC input and Anton Bauer Gold Mount, the BT-LH900A brings the same high level of performance and convenience to OB vans and studio/control rooms.
For monitor rack applications, up to 99 units can be controlled from and external PC via RS-232C and GPI controls.
It provides for high-brightness, high-contrast viewing up to a 170-degree viewing angle, both horizontally and vertically, that minimizes color variation and ensures sharp images.
FEATURES
# Additional peaking for easier lens focusing
# Supports 720p/50 format for global versatility
# Heavy-duty rear panel construction aids in connector stability
# Lightweight at 4.4 lbs, compact size of 8-9/16" (W) x 6-15/16" (H) x 2-7/16" (D)
# 8.4" screen size, 4:3 aspect ratio, 1024x768 (XGA) panel
# Approximately 16.77 million colors
# Selectable color temperatures
# Multi-format: 1080/24/25P, 1080/60/50i, 720p, 576i and 480i/p auto selectable
# Real-time waveform monitoring function in 16:9 mode
# Detachable control panel
# Independent control knobs for brightness, contrast, chroma, peaking/phase
# Power requirements: DC12V (11-17V) 22.8W includes low battery warning
# Built-in CineGamma table for use with AJ-HDC27 VariCam
# Equipped with marker, underscan, anamorphic and blue-only functions
# Five user mode settings can be saved and recalled
Paypal preferred.
FEATURES
