Panasonic BT-LH2550 25.5" Production Monitors available for $2995 each.
These monitors are Panasonic Factory B-Stock with a 90 Day Panasonic Warranty.
The monitors look to be new and unused.
http://shop.texasmediasystems.com/Panasonic-BT-LH2550-255-Multi-Format-Color-LCD-Production-Monitor-w-native-1920-x-1200-IPS-Panel-BSTOCK_p_585.html#
BT-LH2550 Features:
1920 x 1200 resolution (WUXGA)
Six color space settings for use in print to digital graphics to HD video: SMPTE, EBU, ITU-R BT.709, Adobe 2.2, Adobe 1.8, D-Cinema
Wider color space than CRT models with two new color space modes Adobe gamma 1.8, Adobe gamma 2.2 and D-Cinema gamma 2.6
Wide 178 horizontal and vertical viewing angles
New split-screen function plays dual live pictures (1 each: SDI, DVI, Component or Video)
Calibration hardware interface for chroma and luma (with built-in Application Software)
Built-in waveform monitor and vectorscope functions from SDI (HD/SD) input (representing all picture lines)
Exceptionally accurate color reproduction and improved contrast and black levels
Three-dimensional 10-bit 3D LUT offering virtually the same color
Offers a variety of professional functions including split-screen/freeze frame (live input vs. freeze frame), marker and blue-only, and cross hatch overlay display
Time code and closed caption capable (closed caption on video input only)
Embedded audio decoder on board (via Headphone Jack)
8 Channel audio level meters
Cine-gamma Film-Rec compensation function for use with cameras such as the Panasonic AJ-HDC27 VariCam HD Cinema Camera and the new AJ-HPX3700 and AJ-HPX2700 P2 HD VariCam camcorders
Inputs/outputs include: DVI-D input and two HD-SDI/SDI Auto switching inputs with switched output, component video (Y/Pb/Pr), RGB, PC RGB, external sync, RS-232C/GPI remote control terminals, speaker and headphone jack
Five programmable user buttons for easy access to functions
Desk stand included; compatible with VESA mounts (100mm x 100mm or 200mm)
Separate 24 Volt AC Adapter supplied; AC cord (5.58 ft.) and 4-pin XLR DC cord (6.56 ft.) included
One-year warranty (parts & labor
BT-LH2550 Features:
