Excellent Condition.
Includes carry case
The BT-LH1700W 17" widescreen production-quality monitor features two auto-switching SDI / HD-SDI inputs, waveform monitoring, and freeze frame/split screen functions. Desk stand is included.
• High-speed response - no blurring thanks to our overdrive circuit
• Industry's lowest delay - Image Processing Circuit (I/P conversion algorithm)
• Waveform monitor - a superimposed function that graphically displays luminance levels from zero to 110 IRE in any of the monitor?s four corners
• Freeze frame / split screen - frame grab for scene comparison and critical color matching
• Two dual-rate SDI HD or SD inputs - (one with Thru-Out) with auto sensing
• Component Input on BNC connectors - Y, Pb, Pr and PC RGB inputs
• Faithful color reproduction - closely matches chromatic ranges of CRT monitors
• Diagonal line compensation - smoothes out "jaggies" for improved SD response
• WXGA resolution (1280 x 768)
• 176 degree viewing angle up/down and left/right
• One-piece design - no umbilical cord or separate AC power supply
• Frame marker lines - 4:3, 16:9, 2.35:1 or background shading at 0%, 50%, or 100%
• Amplified stereo speakers - two RCA pin jacks input or optional de-embedded audio on SDI
• AC or DC power - 117 Volt AC or 12 Volt DC inputs (4-pin XLR)
• Color temperature selection - D9300K / D6500K / D5600K / User Settable
• CineGammaTM (FILM-REC) compensation - expressly for VariCam monitoring
• GPI and RS-232C ports for external control
• Preset / manual picture adjustments with indicator lights
• VESA mount - both 100mm and 75mm mounting is possible
• Rack mount - fits in standard EIA rack with optional mounting kit
• Tally lamp - red or green
• Desk stand included
Includes carry case
