Panasonic AW-HS50 Sub-compact Switcher w/ built-in MultiViewer
Panasonic Factory B-Stock with 90 Panasonic Warranty
Buy online here for $2995 with Free UPS Ground Shipping
http://www.panasonic.com/business/provideo/AW-HS50N.asp
Overview
Overview
The sub-compact, multi-format live HD/SD AW-HS50 switcher offers 10-bit processing, four HD/SD-SDI inputs and one HD DVI-D input, as well as a built-in MultiViewer, Chroma Keyer, Aux Bus, 1080/29.94PsF support, and more.
Ideal for mobile production, AV facilities, event video and more, the half-rack width HS50's built-in MultiViewer allows users to view four, nine, or 10 images on a single display — significantly reducing the cost, size, and weight of a complete HD production system. The adjustable MultiViewer outputs can also be used to provide a multi-image large-screen presentation display. Other advanced functions include dedicated hardware for picture-in-picture (PinP) with dissolve transitions, switchable upconversion, color correction, a chroma/linear keyer plus a downstream keyer (DSK), auto or manual video transitions, wipe and PinP preset memories, and frame memories.
As a key component in Panasonic's first complete Internet Protocol (IP) production system, the HS50 also offers an IP link to the new AW-RP50 remote camera controller. This link enables remote switching of the remote controlled camera video on the HS50's AUX bus, and other unique functions The AW-HS50 has built-in, switchable 10-bit frame synchronizers on each input, ensuring reliable, glitch-free switching even with non-synchronous sources such as remote camera feeds, small camcorders, and computer graphics.
The HS50 has four HD/SD-SDI inputs and one HD DVI-D input, two HD/SD-SDI outputs and one scalable DVI-D output. Additional standard features include an on-screen display (OSD) for viewing switcher settings, GPI input, camera tally outputs, an Ethernet control interface, 4-pin XLR 12VDC input, and an AUX Bus for a versatile production workflow.
- 5 input, 3 output switcher in sub-compact ½ rack-width design
- AUX bus, PinP, Chroma Keyers, 10-bit frame synchs
- Measures only 8 ¼" W x 2-5/8" H x 6-15/16" D
- 10-bit, 4:2:2 HD or SD live switching
- Weighs just over four pounds
- Supports 1080/59.94i, 1080/23.98PsF, 1080/24PsF, and 720/59.94p
