Panasonic AJ-P2AD1G SD Card Adapter for HVX-200a
ibezdechi
I'm actually getting ready to take the plunge and purchase a Panasonic AJ-P2AD1G which allows me to use standard SD cards on the HVX-200a.
Now what kind of SD cards will the adapter allow me to use? Is there a standard SD card that the adapter will use?
Does anyone have some field knowledge about going about this way for video storage on this camera? Am I only able to use one adapter at a time or can additional SD card adapters be used in the remaining slots working in tandem?
You might want to check that this card adapter will work with the HVX200a firmware. This adapter is designed for using micro-p2 in a full sized slot. Use of SD cards is not guaranteed, though it might be fine....just don't bet the farm on it. Full sized used P2 is becoming more reasonable so you might want to look at that also.
Grant
Recollection is fuzzy.but I don't think that adapter will work with an HVX200; I seem to recall that it will.only work with AVC-Intra-enabled cameras...
