[FS: General] Panasonic AG-HMR10P recorder and AG-HCK10G camera POVCAM Kit with EXTRAS!
Status
Not open for further replies.
FlacaProductions
Panasonic AG-HMR10P recorder and AG-HCK10G camera AVCCAM POVCAM Kit with EXTRAS - $3500+ value.
Now Listed on Ebay starting at $2500 or buy-in-now at $2750.00
Please email me direct: FlacaProductions@mac.com
This kit is nearly everything you need for a high-quality HD POV/Lipstick setup. Just add your mounting hardware and an SD card and you're ready to go.
Amazing performance from a very small package. Only 17 hours of use!
The AG-HMR10 handheld AVCCAM HD solid-state recorder puts the flexibility of recording and viewing high quality 1080 and 720 AVCHD content directly in the palm of your hand. AVCHD recording is superior to HDV, providing double the recording time and higher quality than older MPEG-2 compression used in HDV formats.
The battery-powered HMR10 can be teamed with the ultra-compact AK-HCK10 Full HD camera head (POVCAM) to form a versatile, point-of-view camera/recorder system.
And because its equipped with an HD-SDI in/out, the HMR10 can also serve as standalone recorder for any HD-SDI-capable camera, switcher and deck.
The ultra-compact, mountable AG-HCK10 HD camera head (POVCAM) teams with the AG-HMR10 AVCCAM handheld recorder to offer a low-cost Full HD camera recording system for a wide range of applications. Connected to the HMR10 recorder with a detachable cable, the HCK10 captures 1920 x 1080 high definition video using three 1/4.1" 3.05 megapixel 3-MOS imagers for recording by the HMR10 recorder in the AVCHD format, which provides double the recording time and higher quality than older MPEG-2 compression used in HDV formats.
INCLUDED:
HMR10 deck
HCK10 camera
2 - VW-VBG260 7.2 V 2640 mA batteries
1 - VW-AD20 AC Adapter/Battery Charger
1 - AG-C20003G - 9-foot, 8-inch cable (model AG-C20003G)
1 - Lens Coat - Neoprene Lens Pouch to protect and store the camera head - $23 value
1 - Lens Coat - Neoprene Body Bag to protect and store the deck - $27 value
1 - Hoodman screen shade - to aid in viewing of the screen outdoors - $40 value
1 - Hoya 43mm Clear/UV Filter - $20 value - for the standard camera lens
1 - Tiffen 43mm Circular Polarizer - $43 value - for the standard camera lens
1 - Century Precision Optics .5 Wide Angle Adapter - $165 value
1 - Tiffen 67mm Wide-Angle Circular Polarizer - $98 value (fits the wide-angle)
Everything - including all lenses/filters/adapters - is in perfect shape and ready to go.
Buy a very basic kit at B&H for $3100.00 - buy it here with all of these extras for much less.
THE DECK (S/N: J9TSA0140)
The HMR10 records stunning full HD 1920x1080 resolution images onto low-cost SD memory cards in three recording modes - the highest quality PH mode* (average 21 Mbps/max. 24 Mbps), HA mode (approx.17 Mbps) and HG mode (approx.13 Mbps). The fourth recording mode, HE (approx. 6 Mbps), records at 1440x1080. On a single 32GB SD card, the HMR10 can record for up to 3 hours in PH mode and up to 12 hours in HE mode.
The handheld unit records in HD formats including 1080/60i, 1080/50i, 720/60p and 720/50p. With input from the AG-HCK10 camera head, the HMR10 will also record 1080/30p, 1080/25p and 1080/24p. The handheld unit gives users instant access to content in thumbnail clips and offers a variety of playback functions and solid-state recording modes. It features a built-in 3.5" LCD screen, flexible operation controls, and offers professional interfaces including HD-SDI input/output, HDMI output and USB 2.0.
When teamed with the HCK10, the HMR10 is ideal for a wide range of applications fin nature observation, video production, newsgathering, law enforcement, surveillance, sports, healthcare, education and much more.
One-touch operation user button (choose from 11 functions for instant access)
AG-HMR10 includes two VWVBG260PP1 7.2 V 2640 mA batteries
For longer battery life, the VWVBG6PPK 7.2 V 5800 mA Battery can be used (Requires VWVH04PPK Battery Pack Holder)
HD images can be downconverted and output as SD images (via HD-SDI input and HD/SD-SDI output)
Time and date and TC/UB can be inserted into the recorded signal
Versatile Solid-state recording and operational functions, including shot mark, pre-record, record check (2-sec playback of previously recorded clip for confirmation), last clip delete, auto record, metadata recording, LCD image reverse, index flags
Convenient playback functions (resume playback, repeat, clip fast forward/rewind, frame by frame playback)
Waveform monitor and simplified vectorscope display
Equipped with internal speaker and headphone jack
AVCHD video files can be quickly transferred to a hard drive for use on the web
Additional features include color bar and tone, key lock, camera remote controls (compatible with camera remote controllers for AG-DVX100, AG-HVX200, AG-HMC150, AG-HMC40 Series)
Connects easily to monitors or large displays via HDMI Output Terminal for playback; Auto repeat playback function for digital display applications
3.5 color LCD monitor displays clips in easy-to-access thumbnail view * Lightweight (1.52 pounds), ergonomic design (3.78" W x 2.07" H x 5.24" D)
Useful LCD Reverse flips the image on the display (this does not affect the recorded image)
Operates on battery or 7.2V DC power (power for AG-HCK10 camera is supplied by the AG-HMR10)
The cable connecting the HCK10 to the HMR10 is 9-foot, 8-inch cable (model AG-C20003G) and is included . Available optional cables include a 65-foot cable (model AG-C20020G) for longer distances.
THE CAMERA (S/N: J9TSA0247)
The camera head features a 12X optical zoom lens with 10X digital zoom, (up to 120X), optical image stabilizer (O.I.S.), a built-in 2-channel microphone and a range of advanced tuning functions, including matrix, knee point, adjustable detail and chroma, white balance and zebra settings. Iris, focus and zoom are remotely controlled by the HMR10 recorder. It is powered by the HMR10 recorder.
Sleek, pocket-sized design (2.1" W x 2.2" H x 4.8" D)
Allows POV-style image capture from a long distance
Features 1/4" 20 socket for easy mounting.
Optical Image Stabilizer (OIS) function ensures shots remain clear while walking or zooming
Dynamic Range Stretch (DRS) feature suppresses blocked shadows and blown highlights
Slow shutter and synchro scan functions
Color control and skin tone detail functions
Cine-like Gamma Curves (seven different gamma modes)
HD focus assist functions and slow shutter and synchro scan
It has endless point-of-view applications for use in nature observation, video production, newsgathering, law enforcement, surveillance, sports, healthcare, education and much more.
43mm lens filter size (lens options available)
Weigh: approximately .61 pound
Cables are detachable (from recorder and from camera head) for total flexibility
Status
