Panasonic AG-CX350 OIS not working properly
I seem to be having an issue with the OIS. In any OIS mode, the image rotates when I stop moving the camera. The image rotates slightly, then snaps back into place. It's a somewhat abrupt movement, and makes the end of the pan unusable.
Here's a video of the issue:
https://youtu.be/023MOzxvXgs
I've known some cameras to do this a little bit when OIS is on, but this seems to be way too much over-correction. I do know it's best to have OIS off when on sticks. I only used a tripod in this video to show that it's not my shaky hand causing the issue. The issue does happen when handheld, and at any movement speed, which is my main concern.
Please if you have a CX350, do a quick panning test with OIS on, and look for any extreme image rotation issues at the stop of the pans. Post you results here to see if this is an isolated issue with just the camera I received, or if it's more widespread and affects all CX350's.
Turn the Hybrid O.I.S. off. Hybrid should never be enabled when the camera is on a tripod.
Hi Barry. Thank you for the quick reply. I noticed this issue when I was panning hand-held. I only used a tripod in the video to see how bad the issue was, and to make sure it wasn't my shaky hands causing it. When hand-held, the issue is just as bad. I will test hand-held without "hybrid" on, just regular OIS.
UPDATE: I tested it hand-held with Hybrid OIS turned off, and that indeed fixed the issue. With Hybrid OIS turned on and shooting hand-held, the image rotates abruptly at the end of pans.
I will keep Hybrid OIS off for good.
