[FS: General] Panasonic 17" production LCD BT-LH1760P
Evangelos Achillopoulos
Monitor is used always in Portabrace bag in perfect condition. Portabrace On Set production bag is included.
The high-performance BT-LH1760 17" LCD production monitor combines an advanced In-Plane Switching panel with outstanding black level and high-end functionality to provide exceptional performance for critical monitoring and viewing. Because it has a 120-Hz double-speed drive, twice that of current LCD monitors, the BT-LH1760 handles fast motion content exceptionally well and reduces image blur to a level never before seen in a professional LCD display. Designed with a 3D Look Up Table (LUT) and 10-bit image processing, this AC/DC high definition monitor delivers a remarkable picture that will give you the edge in the studio or in the field.
The LH1760 is equipped with a built-in waveform monitor and Vectorscope, as well as five function buttons that assure quick access to value-added features such as pixel-to-pixel display, cross hatch, split screen, audio level meters, time code and closed caption (from video) displays. With a rugged diecast aluminum frame, low power consumption and quiet operation, the LH1760 is ideal for a wide range of HD production applications in the studio or the field.
  • 1280 x 768 resolution with 1:1 1920 x 1080 mode for zooming and focus
  • Wide 176° horizontal and vertical viewing angle
  • Built-in waveform monitor and vectorscope (from HD-SDI, SDI ) both display all picture lines
  • High contrast, improved black level
  • Image-enhancing functions including split-screen/freeze frame (live input vs. freeze frame), Marker and Blue-only, H/V delay display, monochrome and Cross Hatch overlay display
  • Cine-gamma (Film-Rec) compensation function for use with cameras including the Panasonic AJ-HDC27 VariCam HD Cinema Camera and the new AJ-HPX3700 and AJ-HPX2700 P2 HD VariCam camcorders (it works also for S-Log and Alexa)
  • Embedded audio is standard
  • Inputs/outputs include: DVI-D input and two HD-SDI/SDI Auto switching inputs, component video (Y/Pb/Pr), RGB, PC RGB, external sync, speaker and headphone outputs
  • Headphone output can output embedded audio and audio level meter from HD-SDI,SDI
  • Energy saving -- consumes 50% less power in AC operation than prior models and includes an automatic power save mode
  • Built-in AC/DC power supply
More images here http://bit.ly/nRjrSe
Price: make an offer
