I finally bought a GH-1 and hope to share some observations and experiences in this forum quite soon. But first, here's a quick question:
MediaInfo v. 0.7.27 shows "NTSC" as the "standard" on my .MTS files -- even though I have a PAL GH1. Is this normal for MediaInfo or did someone foist an NTSC camera on me?
Is there an objective way to verify that my GH-1 is indeed producing PAL files? The "Frame rate" is shown as 50.000 fps, which would seem to indicate PAL. Thanks for any insights.
Here, for the record, is the readout:
General
Complete name : V:\PANASONIC LUMIX\4\00005.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 30.2 MiB
Duration : 26s 505ms
Overall bit rate : 9 549 Kbps
Maximum Overall bit rate : 18.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Duration : 26s 500ms
Bit rate : 8 970 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Original frame rate : 100.000 fps
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.195
Stream size : 28.3 MiB (94%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Duration : 26s 496ms
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Stream size : 621 KiB (2%)
General
Format : BDAV
Video
Menu ID : 1 (0x1)
Format : AVC
Height : 720 pixels
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Audio
Menu ID : 1 (0x1)
Format : AC-3
Bit rate : 192 Kbps
