PAL slow-motion 50p to 25p
After finally updating Premiere Pro for AVCHD compatibility I tried to run my first slow-motion test with the GH1.
But I seem to have problems with the workflow yet. Is it the same as converting NTSC 60p footage to 24p, just at 50/25?
Here's what I did:
Shot some test footage in 720p AVCHD mode at 1/100 shutter. Opened a new 25p project in Premiere. Imported the clips and put them in the timeline. No slow-motion. Do I have to set the speed to 50%? Tried it, but apparently it's no real slow-motion then of course. Am I just missing something or doesn't it work properly?
Thanks for any replies!
EDIT: Got it. For anyone also working with Premiere: Right-click the clip, check properties. It should show 50 fps. Right-click again, select "Interpret footage" (could be named differently as I'm translating from my German Premiere). In the pop-up window, select "Different framerate" and type in 25 fps. Then put the clip in the timeline and it should play in slow-motion. Clip properties still show 50 fps though. But it works, so this should be the deal.
Im a FCP person, but its nothing like 60 to 24. You shouldnt have to interpret? Just drop the 50p straight on 25p timeline reduce speed to 50% - not sure how premiere works anymore, but make sure it does not have any frame blending turned on.
in vegas i just do the math, if it's a 10 second clip shot at 60 i pull it out to 25 seconds on the time line, and i might be doing it wrong but it looks smooth to me, the only difference i'd think would be the math is easier in the pal version!
