pal/ntsc switchable?
Martin Landsburg
Hi, I've been searching for this one on the forum, couldn't find anything...
maybe it's my misunderstanding, but does this 'upgrade' that Canon seems to offer for a fee (how much?) make the A1 PAL/NTSC switchable? Would it give a Pal model the 24f mode?
This is what the Canon site says:
For a fee, users can send their XH A1/XH G1 to Canon Service Centre for optional 50i/60i upgrade conforming to PAL or NTSC standards
Thanks,
Martin
500 bucks. Should give you 24F, 25F, 50i and 60i. For experiences with this, you might try some XL H1 forums and find people that have upgraded those cams.
It adds 50hz switchability to the menu. 25F and 50i are added as options, although the camera has to reboot (quickly) just as it does when you switch from 60i to 24F. It's reclocking the CCD's.
Not a bad option if you're ever going to travel to Europe with the camera. It's also nice for a slightly different slowmo effect when converting 50i to 25p and conforming to 24p. It's less slow than 60i to 24p. (2x vs. 2.5x slowmo)
well that is very interesting indeed. Someone who would be doing commercial work for both continents, for example, could do the same shot twice: once in Pal mode and once in NTSC.
I wonder if that is a more efficient way than converting Pal to NTSC or vice versa, in post production? Pal to NTSC if conforming 25 to 24? NTSC to Pal 30f to 25f? Not sure if I'm technically acurate here.
Production wise, you would spend twice as long on every shot. I have heard of software like Atlantis and others that convert one standard to the other quite well.
What do the users here think?
A) Take two shots, one in each mode (1 shot in PAL, 1 shot in NTSC)
B) Convert in Post production.
Thanks Philnerd and Elton, for your input!
