PAL HVX200 and FS100 Connection Issue
onwards08
Hi all:
This is the first time I am posting here, and look forward to the community's kind response and support.
I have a HVX200 (PAL) and I bought a used FS100 - however, even after reading the firestore manual on how to connect the camera so it would start recording - it suggests changing the 1394 setting, under Option 9, in the camera's menu, to 'BOTH' which didnt work. Later, after reading some posts on this forum, I saw somewhere to change the same setting to 'EXT' - I tried that but it still does not start recording. Just to establish the present settings, which are: DVCPRO HD footage (format to record), it's in TAPELESS mode, and I tried recording with P2, P2 PN, & QUICKTIME media (non-worked). The firestore is version 3.0, and I formatted it before use as well. Lastly, when I press the display button a couple time on the firestore, it shows DV NTSC - not sure if this is the reason for the firestore not recoridng the data. The camera and the firestore do communicate, since each time when i click record on the camera, the firestore blinks, goes of the pause mode, but no recording takes place.
I would really appreciate some help to trouble shoot through this delimma, since I hve been trying for over one month now without any luck at all, and havent yet been able to test the camera as result.
THANK YOU VERY KINDLY.
NTSC Firestore does not work with a PAL camera.
I run in to the same problem and had it patched to PAL at Focus Service.
Frank
