BrenMyster
Am i right in thinking that you can pick which mode to shoot in with the EX?
Can it switch between PAL and NTSC?
Cheers
Cheers
It's even more complicated than that (at least if you live in Brazil) - http://en.wikipedia.org/wiki/PAL-M since PAL-M is a TV system with the resolution and frame rates of NTSC, but with PAL colour coding.Pal and NTSC traditionally referred to both resolution (Pal had more than NTSC) and frame rate (25p/50i PAL and 30p/60i NTSC).
"PAL" and "NTSC" really have no meaning at all with HD, as matthew77 has correctly said, and IMO Sony should really have referred to 50Hz or 60Hz areas rather than PAL or SECAM. As it is, in Brazil, they need to specify an "NTSC" area to get what they want (60Hz HD), even though all SD broadcasting is PAL.......HD media now means that there is no difference between resolution with PAL and NTSC. But there is still different framerates. (PAL = 25p, 50p, and 50i and NTSC = 30p, 60i, and 60p).
