PAL 16:9 progressive to NTSC
amiganr1
hi:
i shot in squeeze mode 25p and i want to release a dvd in USA so i want to convert to NTSC.
it has to be converted to 30 right?
which is the best tool to do this?
thanks in advance.
Re: PAL 16:9 progressive to NTSC
Agreed. Don't try to take 25P to 60i, take it down to 24P (which, as MovieSwede says, is actually 23.976). Encode your DVD at the 23.976 frame rate, and the DVD player will take care of converting it to 60i for you.
and can you notice any difference when it is converted to 24?
also, do i have to make twice the dvd menus in encore for example?
you have to choose pal or ntsc before starting the project so what to do?
well as im understand when you code the menu and so on, its dependent on the orginal mpg. The new one will have different speed so a lot of the settings cant work with the old like chapters. The best thing is to just make a new menu. You have the orginal menu files left?
About quality. It will not look exactly the same. But it will look as close as it will get when you make a 23,976 NTSC version. And it will look better than playing PAL on an NTSC-tv.
