LighthouseMedia
[FONT=Arial, Helvetica, sans-serif]This is a Paglight C6 Video Light kit in excellent condition with no problems or issues. I have included a hard carry case, extra battery pack, and extra bulb to complete the kit. The base kit without any extras and only one battery retails for $419 new. Extra battery retails for $149 new. Kit includes all original accessories and manual. Here is your chance to get the entire kit at a steal!! Guaranteed to be in great working order.
ASKING PRICE $375
HERE IS A DESCRIPTION OF THE FEATURES:
Paglight C6 adds vibrancy to the colour in your videos.
This broadcast quality lightingkit, designed for use with miniDV cams, will bring your images outof the shadows and give them thatprofessional touch.
The kit includes a 6V 7 Ah battery,a charger, and professional accessoriessuch as a soft-light diffuser and filterfor daylight shooting.
Lamp-changing is quick and easy.Run-time is 2Ý hours with a 20W lamp
The limited choice of high-quality, on-board camera lighting for mini DV Cams has prompted PAG to develop a miniaturised version of its popular professional Paglight.
This new broadcast quality camera light is cool-running, has a focusable beam angle, and a patented system that makes bulb changing quick and easy.
The Paglight C6 is constructed from a glass-reinforced engineering polymer that provides impact resistance and temperature stability. The combination of this modern material and the patented heat dissipation system ensures the Paglight C6 is cool-running and comfortable to handle.
The lamphead is fully-focusable, with a smooth transition from spot to flood. The ability to change the beam angle allows you to compensate for light loss over distance within the same frame size. Designed to complement available light as a 'fill' or front light, the Paglight C6 will bring your images out of the shadows and give your videos the professional touch.
The Paglight C6 incorporates many features of the larger professional version. A rotatable accessory ring is fitted to the front of the light that accommodates a range of snap-in accessories. The frosted diffuser is used to soften the harshness of direct light shadows. The dichroic filter is used to change the colour temperature of the tungsten halogen light output to match daylight. Barndoors are included to flag off unwanted light.
The Paglight C6 features a patented plug-in lampholder system that makes fitting a lamp quick and easy. The light is supplied with a lampholder and 20W 6V, G4-size tungsten halogen lamp (10W and 30W lamps are also available). Additional lampholders enable change between lamps of varying wattages without directly handling the lamp. When not in use, lampholders can be stored in a heat-resistant polymer lamp protector.
The support base of the lamphead is a multi-directional mounting which allows the light to be adjusted vertically and horizontally. The pivot points are friction adjustable to maintain the desired position in all situations of use. The Paglight C6 is supplied with a square shoe plate allowing the unit to be mounted to camcorders with an accessory shoe.
A flying lead terminated with a professional quality latching connector allows the light to be powered from its own 6V 7Ah Ni-Cd battery. The rechargeable battery pack, weighing little more than 1kg, is provided with a detachable shoulder strap. When fully charged the battery will provide 2 and a quarter hours of run-time with a 20W lamp.
A wall-plug mains charger is included that will charge the pack in 3 to 4 hours, from fully discharged. It will automatically recover the battery prior to fast-charging, if it has been deeply discharged. It provides a maintenance top-up charge after full charge. These automatic functions are indicated by a single LED. The charger has an interchangeable power plug (US/Japan, Euro and Australian plugs are available on request).
Good lighting is an art, yet the basic principles are simple. If you would like to be recognised for the work you produce as a camera operator, it is essential to understand how to control light and achieve a good result with limited resources.
[/FONT]
ASKING PRICE $375
[/FONT]
