P2 Viewer Audio Hardware
Just switched from a powerbook to a pc for card off loading. I installed p2 viewer and when i tried to run it viewer gave me an error message "the required audio hardware cannot be for on your computer." i have no idea what that means. any help?
I have a toshiba satellite a135 celeron M 1.6.
I thought it was a Vista Issue.,...I have Fujitsu....2 gig ram 200 gig hard drive....grrrr.... tried disabling the audio no help...
P2Viewer on Vista AMD 64...
I've got a producer who is trying to install P2Viewer and is getting this error on her Windows Vista computer. Is there a work-around for this? I thought that Vista 32 and 64 was supported for P2Viewer?
I have been told that P2CMS is not supported.
"The required Audio hardware cannot be detected on your computer"
Thanks!
e
No one is using P2Viewer on a Windows Vista computer? Am I missing something here? Outside of using an NLE to look at P2 files, how are people viewing and logging P2 footage outside of the edit suite?
Thanks,
e
Well, I pulled the trigger on a used Dell laptop running XP to the tune of $400 today to resolve this issue for our client.
Totally unacceptable, but the client is more important to me than being right about this huge gap in Panasonic's support for their flagship video format.
Actually, the Dell laptop running only P2Viewer for our clients is something I'll be bringing on all subsequent shoots as a loaner for viewing dailies. A good result from a crappy Panasonic-induced challenge.
Hey Panasonic! Fix the driver issue for P2Viewer and P2CMS in Vista 32 and 64?
:Drogar-BlackEye(DBG
e
Vista
Vista
Frustrating, isn't it?
I have had this same issue on every Vista machine I've tried. According to the Panasonic site the P2 drivers & P2 viewer are meant to work with at least Vista Business "and newer", but I've found they don't work on a brand new Vista Ultimate installation.
There are some workarounds & other information posted here:
http://panasonic.sixbullets.net/
Alas, none of them worked for me.
Perhaps you'll have better luck.
check out this tread in workflow ..P2 VIEWER AND P2CMS ISSUE in windows vista.
this is how I got round this issue and it works perfect...
regards.. mj haughey
I am having the same issue, can someone help? I dont know what to do and cant find any information
I just tried you suggestion Val, but it doesn't work for me. I keep getting the same err msg.
I'm also using Win 7 Pro 64. I've downloaded and installed what I understand is the Win 7 64 ver from Panasonic's support site.
Only reason I keep trying is I've been convinced I must be doing something wrong and that Panasonic cant still not have a ver for Win 7 ?????
What is everyone else using? I've tried P2Forge and it seems to work well. Looks like I must buy it.
Sorry to resurrect an old thread, but has anyone, anywhere, ever found a solution to this issue?
I just picked up an older Toshiba Satellite running Windows XP SP3 to be used as a P2 offload station in the field, and I keep getting the "Required Audio Hardware" problem.
Is there a solution?
