P2 storage devices - life expectancy
khmuse
Tech Guru
Has it been established that the P2 format utilizes EEPROM internally? The reason I bring this up is that there is a limited number of write/rewrite cycles for EEPROM devices. Depending upon the technology and density, it is typically 10,000 - 100,000 cycles. They don't abruptly fail; just a few 'cells' get stuck at either logic low or high. Since the P2 format use them in a pseudo raid configuration, there may fault tolerance built in to the P2 format, so it may take a fair number of bad 'cells' before the card exhibits problems (it may just have slightly reduced capacity under these conditions).
We use EEPROM (both standalone and embedded) in a number of products that my company manufacturers and I can assure you that they do eventually exhibit this problem.
I must say that I am really looking forward to the HVX200 and have been going tapeless for a while already with the DVX and DV-Rack, so life expectancy issues or not, it won't change my interest level (at least for the HVX).
P2 is using SD cards, consumer type. They are selected for speed, only the top 5% are used. Life expectancy is guaranteed 100,000 rewrites and the PCMCIA connectors are guaranteed for 30,000 inserts/removals. In other words, if you insert/remove your card 8 times a day, after 10 years you will need a new one. If you leave the card inside the camera and you re-write it 10 times a day, you will need a new one after 27 years. Not bad, eh?
oh crap. I was planning on having a 30 year anniversary party for my HVX and using a mirror to tape itself in bed since it will have serious arthritis by that time and wont be very mobile. Kiss those plans goodbye. Damn.
